Clearance Bulb Removal Problem
just the bulb socket or the whole assembly?
if just the socket, turn counter-clockwise and then pull, sometimes it needs some extra force to twist and remove it.
if the whole assembly, you should remove the bumper, much easier that way on the right side and impossible to do without removal on the left side
Yeah, those can be pretty tough to pull sometimes, try the turn and pull method maybe even get some plyers there to help on leverage.
you can get just the socket if you damage it getting it off, so just a $10 part if it is damaged or corroded
Are you talking about the front turn signal indicator, side marker bulb or the parking lamp bulbs?
888.280.7799 | 6am - 5pm PST
thinkinmini
04-20-2016 09:46 PM
Norton70
04-11-2016 11:09 PM
BlueMCS
04-07-2016 09:29 AM
R50/53 How to remove lock mechanism
Ej Spaziani
04-04-2016 11:16 AM
