06 R53 Window Dipper Gremlins
Was driving to work this morning when, without warning, my driver's side window began dipping and then going back up completely at random, like it does normally when you're opening the door. Door was completely closed/locked. The dome light was also on, but the door was definitely closed. When I to work, I confirmed the door was completely closed and locked the car. Dome light went out, but the window continued to go slightly down and back up completely at random, sometimes going a full minute or more before cycling again. It's raining, so I ended up having to disconnect the battery to keep the window fully up.
It sounds like a door sensor malfunction to me, but I'm not too familiar with Minis and I've never had a car with the window Dipper function. Any ideas?
Battery doesn't have a date stamp on it but has shown no signs of acting up and has no corrosion. Looks fairly new, but you can't really go by that with an enclosed battery like the Minis have.
Check the passenger side carpet for dampness? The BC1 module is mounted down there and often gets flooded from a loose sunroof drain, or a leak around the windshield/firewall.
Other than that, I would check the battery again. Many posts I've read had the electrical problems clear up even though the battery appears to start the car without a problem.
Checked, no dampness, everything looks clean and good. I double checked the battery leads and reconnected the battery and the problem's still there. Will the battery test as being bad? I don't have a problem replacing it, but I'd rather not spend $150 if I don't have to.
That seems to be the problem with MINI's from other posts I've read. The batteries seem to be good, test as good, but the problems seem to be fixed with a new battery.
How old is your battery? Maybe it's time to replace it if it's 4 years, or more. Some people will wait for the battery to go bad, but some don't want to deal with the inconvenience of getting stuck with a dead battery someplace.
Reach behind the switch panel...make sure it is plugged in tight...
Also do you have a "auto-up" window circuit installed...it's aftermarket, and might have failed.
To re-initialize the window dipping...if I recall right, just hold the switch in the up position for a few seconds...if I recall, more than 8...might help...
I might suggest you look around...for a cut or rub in the wiring...maybe where it goes in and out if the door?
JWA
03-23-2016 08:37 PM
JWA
03-21-2016 02:57 PM
JWA
03-20-2016 04:29 PM
