Timing chain broken cam gear bolt snapped
Old 08-11-2016 | 10:31 PM
98Ekhatch's Avatar
98Ekhatch
bought the car Friday this past week. didn't even make it home befor it died . popped the hood found the intake inlet boot cracked. replaced boot still no start. replaced battery and starter still no start just clicking. pulled dip stick and it didn't go back in so led to believe chain tensioner guide broken,pulled valve cover to find no cam chain or intake sprocket. found sheared bolt was able to pull it out along with the sprocket. luckly its covered just took to bmw today. 2009 mcs. 57k miles.
Old 08-12-2016 | 07:07 AM
MiniToBe's Avatar
MiniToBe
Crazy, huh....when you test drove the car, did you hear or notice anything. did you pop the hood and saw anything prior to buying the car?
Old 08-12-2016 | 03:12 PM
nkfry's Avatar
nkfry
I'm gonna go out on a limb and say the vacuum pump is seized. We've seen a couple of cars that have had seized vacuum pumps and caused the cam bolts to break due to low oil level.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 08-16-2016 | 02:28 PM
J_RodSS's Avatar
J_RodSS
I had the same thing happen to me a couple weeks ago. I just bought my 07 MCS in June. I put 4k miles on my car and did my oil change. Nothing seemed out of the norm. I put 300 miles on it after the oil change and the car ran fine until i came to a stop light at an exit ramp where the car quit.
I pulled the dipstick and it wouldn't come out but 4 inches. I drained the oil and didn't seen any metal shavings. i pulled the cam cover and found the sprocket laying there with the bolt sheared off and in the bottom of the pan were a couple chunks of aluminum.
Old 08-16-2016 | 02:56 PM
98Ekhatch's Avatar
98Ekhatch
Hey bro coukd u please text me. 7575001806. Wanna ask you some ?s
eliseo1981
05-02-2016 07:44 PM
Zpgray19
04-05-2016 09:28 AM
speedkills66
03-27-2016 12:34 PM
dn09MCS
03-14-2016 09:50 AM
BigM
09-23-2002 03:50 PM
