Idle Woes
Idle Woes
Hi,
I have an 02 r53 and I've been having the intermittent issue of all the gauges dying at idle. This usually only happens when the AC is on, but I've also seen it happen when the steering wheel is turned when the car isn't moving. This on occasion resets the ECU which really baffles me.
Hello, I am not an R53 person but in some other threads i read that it could be your charging system which includes the battery, alternator, and WIRINGs. when did you start having the issue, how old is the battery, if you start the car and remove the battery while running, would the car shut off or get weaker?
when you get a chance, rev the engine a little higher (let's say 2k rpm or something like that [me just throwing numbers just to test the system]) so the alternator can put out some more juice and turn the AC and see what happens, do the same and turn the steering wheel, then do the same with AC and steering are working and see what happens.
InnocentiMini
10-12-2018 06:10 AM
Navigation & Audio Steering wheel controls [forward/reverse] issue
MothAudio
04-03-2016 06:34 PM
