Won't start
It's kind of hard to see from this picture, but I read another post you made a couple of days ago about your car cranking but not starting. Were you working on your car? did you take the throttle body off? from the symptoms you described and your picture I kinda think the throttle body isn't plugged in. I'd check that and also charge your battery.
It comes fromy all the wiring that connects to the starter idk if that's why my car isnt starting I've been trying to find a diagram or something to see where to connect it if you find out let me know please
Check and make sure you don't have any loose grounds. Also, check the connectors on your battery to make sure they're not loose and that they aren't in poor condition. A loose ground or poor connection can cause a not start issue. And of course, definitely check the voltage of your battery to confirm it is not bad. All sorts of weird things can happen with a dying or bad battery in these MINI's. If you need help with testing we have some info at the link below. I'd also possibly plug into your OBDII and see if any codes are present.
http://www.pelicanparts.com/techarti...stallation.htm
888.280.7799 | 6am - 5pm PST
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic118226_4.gif)
Well just changed the harmonic balancer and that's it but I took it to the mechanic and said it was the key but they want to charge me 480$for the new one and programming
Haha your telling me man but the bad that's how it is in Idaho man that's why I try to do my own work because there proud of there work haha and i hope haha or I'm tearing ***
Bgould
09-19-2016 11:51 AM
yellowbox
R59 :: Roadster Talk (2012+)
09-15-2016 06:07 AM
09-14-2016 06:27 AM
