Help mini wont start!?!?
#27
Hey I am having this same problem. 2010 cooper S automatic with a p15E8 code. Mine with a shot of ether will pick up a bit and run but stop shortly after I stop spraying. I replaced the coolant temp probe and cleared the engine codes. Will this code turn off the fuel pump??? Or is that the next part to swap out? Thanks in advance
#28
Check to see if power to the coils . the green wire is hot. if the test light don't light up. and then check the fuse. if its good nine time out of ten it's the bad fuse block in side the car right side kick panel. take to dealer cause dealer because it will have to be re programmed. i had the same problem.
#29
#30
