foamy coolant
You need to do a leak down test to find out why you are getting thick foamy buildup in the tank.
Chances are either a head gasket, cracked head, or failed oil cooler.
And what needs refilled constantly, coolant or oil?
foamy coolant
Thank you for the drain lead. got it opened and done.
Head gasket / cracked head repair are beyond my skill set and would cost much more than the car is worth.
I'm not sure that a gasket failure in the oil coolant-oil filter housing is the problem. there are no leaks in that area.
I add oil before traveling and find it gone after 30 miles.
Thinking I should put it up on ebay for parts
