I need help please
Old 02-24-2017 | 07:55 PM
Matthew Campbell's Avatar
Matthew Campbell
I need help please
I have a 02 mini Cooper s and the engine decided to throw a rod today.
my question is can I use the motor from a non superchargered mini on mine? Like I just need the engine I don't need the supercharger or anything else. I'm hoping I can just swap out parts and get back to driving my beloved mini
Old 02-24-2017 | 08:08 PM
sevin's Avatar
sevin
I think the blocks were identical, the heads were different.
Old 02-24-2017 | 08:40 PM
Matthew Campbell
so as long as my head is fine I could use an engine from a r52
Old 02-24-2017 | 08:43 PM
xsmini's Avatar
xsmini
I don't believe the standard block has the oil squirters for the pistons. I guess they could be plugged, but not sure since I've never seen the innards on a justa.
Nik
Old 02-24-2017 | 09:48 PM
X757XVeritas's Avatar
X757XVeritas
I know it's a different crank in the S versus the non, so id assume there are other differences as well.
Old 02-25-2017 | 08:57 AM
Matthew Campbell
Thank you all for the help.
Old 02-25-2017 | 05:27 PM
User 41921's Avatar
User 41921
The pistons are different with a compression ratio of 10.5:1 instead of the 8.3:1 in the W11. The different crank also uses a different balancer since the snout sizes are different. IIRC the W11 crank is forged instead of cast
Old 02-26-2017 | 07:38 AM
Bernard Barbour's Avatar
Bernard Barbour
No, sorry you can't.
Old 02-27-2017 | 07:42 AM
nkfry's Avatar
nkfry
As above folks have pointed out the lower end is different between the two cars, as well as the exhaust valves are different in the S.
Pistons are different, Crank, associated bearings, rods, oil squirters on the S, inconel valves on the S.
We do have a rebuilt S engine that we're just finishing putting together, if you're still in the market for an engine give us a call and we can help you out.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 02-27-2017 | 10:06 AM
Matthew Campbell
How much? It'll be a month or two before I can put up the money to buy an engine sadly.
Old 02-28-2017 | 11:58 AM
nkfry's Avatar
nkfry
PM'd ya.
Phone:586-792-6464
