Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Hello, ive got an 02 r53. i recently unhooked the battery cables from the battery after a short drive to take the battery out and clean the battery compartment. reason being, im selling the car to a buddy and wanted to thoroughly clean it for him. upon putting the cables back on and tightening them down, i realized i have no power. none. not the gauges, turning the ignition, no dome light, not even the fob will open the door. i took the battery cables off and cleaned the contacts and the posts on the battery. nothing changed. i hooked a battery charger to the posts under the hood to see if i could jump the power and open the hatch back up (i accidentally shut it without thinking) and... STILL nothing. no power to anything, and i made sure there was good clean contact with the charger. what on earth could this be?? any help is appreciated since im scheduled to sell this beauty tomorrow!!! thank you!
So that could cause it to not get power, even if i jumped it from the front? does the positive post in the front run to the back of the car where the battery cable is or something?
Yes i checked it with a multimeter and it checked out okay. there was a small amount of corrosion but i cleaned it afterwards. ive cleaned all connections back there and still no luck.
Not trying to insult anyones intelligence or anything. Are you positive you connected the battery cables to the correct posts on the battery? Maybe put it back backwards?
