Coolant
If the dip stick has chocolate milk on it, chances are you have a head gasket leak. I also read something that a garage can put a tester over the coolant fill tank to see if there are any hydrocarbons present. Antifreeze is not a CHO (nor a hamster cell).
You might have a leak at either the water pump or the tstat. It can leak here but with the engine, hot the fluid evaporates and you don't always see drip on the floor.
You can get a dye at the auto parts store and add it to your coolant...it will show up fluorescent with a special set of glasses (usually goes with the kit) and a flashlight. You should be able to see where it's leaking from...The first place I would check is the filler neck/thermostat housing.
