Pulling to the right.
I have searched the forum and haven't found any thread that addresses this particular pull to the right.
2005 R53: When I am just about stopped, the car feels like it wants to turn right. It's not too bad.
When I am just starting to go from a stop, the car does this pull again, only this time a little more pronounced. The car doesn't pull either way at any other time, only in these two instances. The car tracks down the road like it was on rails. Thoughts?
Jack the front of the car up so the wheels are off the ground. With the engine running and the transmission in neutral have someone press the brake then release it. See if the wheel will spin by hand right after the brake is released. Check both sides to see if there is a difference. I would do the same for the back as well. If a caliper is sticking, you likely just need to lubricate the guide pins.
Definitely sounds like a dragging brake but thankfully it's not severe. Might just be a stuck pin, usually a seized piston would be more severe.
I would spin the wheels by hand without running the engine at first to see if you can identify which caliper is stuck. You can also feel the wheel/brake after driving the car around to see if one is noticeably warmer than the other but it might not be effective because it's not dragging severely.
just my safety 2cents
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
"Feel" doesn't mean grab, "feel" means place your hand close to the wheels in question and see if you notice a difference in radiant temperature.
If you don't use jack stands we just call that "natural consequence."
