R53 Won' Start! Please Help!
Ok so I neglected my car and let it sit for quite some time. When I went to get her going again the battery was dead, so I got a new one. Now the car will light up and the normal chiming happens and the fuel pump primes, but when I turn to start I get nothing, nada, crickets! I searched the forums and went with the cheapest fixes; new key, new battery, new ignition terminal switch and I still have the same symptoms. I decided to replace the starter and still nothing. Same issues. Lights, radio, chimes, fuel pump priming and then when I turn to start nothing happens. I'm so lost, I miss driving my Mini, but ultimately want to sell it. Does anyone have any advice?! Please help me!
Need to make sure the engine is not set up, hence my previous question.
If the motor turns over but the starter is not working you need to test the circuits. I know that other cars have interlocks in place so the ignition sequence is stopped through the key switch if certain sensors are not working. Need to find a schematic on your year Mini and see if this is the case.
You many have a two fold issue, the above, and then assume you had ethanol based gas in the car. Ethanol gas is subject to Phase Separation that results in the water in the air being absorbed into the tank. If the pick up point of the mini is in the water level you are not going to start even if you push. You should check the gas at the fuel rail.
I am also thinking that a code scanner may tell you if some sensors are bad.
Last, you verified you have voltage at the starter?
