Help with code 2885 boost deviation
I have been trying to figure out why my car goes into limp mode and generates code 2885.
The car seems to run fine and then when I accelerate hard it genrates the 2885 code and goes into limp mode.
In testing with a vacuum gauge inline with the wategate I have found that the vacuum seems ok and then when accelerating and it car goes into limp mode I have 0 vacuum. I have no vacuum until I turn the engine off and crank again and vacuum returns. I wonder why all of a sudden I have 0 vacuum at the wastegate. I suspect it must be the boost control valve??? Any ideas would be appreciated. Thanks
Things I have checked
The diverter valve seems ok. Seal and coil are good.
I have put vacuum on the wastegate and it moves.
Turbo spins freely and no play checking with the intake hose removed.
Vacuum is ok at the vacuum pump.
