Coolant fan or resistor
Start the car and let it sit. You should get hot enough to trip the high-speed temp sensor. If both fans engage at high speed then either your low speed relay is shot or the resistor. There is a sticky thread here with the hows and wheres. I have the resistor bypass in place and have a spare "green" resistor in my car with a harness already soldered on with clips as the greenies do not appear to last as long at the goldies.
Should kick on at 234 so if you hit 235 and the fan does not work than I would then get the fan into a position so that I could jump with a power lead to see if they run. If it runs with the jumper, then you need to check the two relays, one for the low and one for the high. I am thinking there is a switching unit fuse as well. Check out this thread that has the fuse and relays listed.
On another type of car the fans were not working, I jumped as above and they worked fine. I then found one relay and one fuse were bad.
https://www.northamericanmotoring.co...nd-wiring.html
So I had to run a jumper from a grounded bolt to the black lead and a power jumper to the bigger red lead and the fan kick on. My guess is the infamous resistor!!
Side note, when it was hot yesterday I had power to both red leads.
Low speed runs through the smaller gauge wire and high speed runs through bigger gauge wire.
So the previous post I did with the car off. I wanted to check some other thoughts out. Went out started the car, no fan ( expected, not warm enough) turned on max a/c. Fan came on, low speed. Turned off a/c,fan stayed on, temp was at 190*. Turned a/c back on and moments later the high speed fan kicked on. Let run for a minute or two, temp never got above 195*. Turned off a/c again and fan went back to low speed.
