Hard brakeline replacement
Old 10-08-2019, 10:08 PM
thevastdifference's Avatar
thevastdifference
thevastdifference is offline
Originally Posted by elightbo
Has anyone done this job? Does the fuel tank need to be dropped?
I, too, am looking for this job. It seems that the lines going above my fuel tank are rusting out.
  #27
Old 10-09-2019, 05:25 PM
50pascals's Avatar
50pascals
50pascals is offline
Originally Posted by Boostmaster
Instead of replacing everything, I would isolate the leaking areas. Double check that you have found all the pin holes. Then simply take a pipe cutter- you can buy at any hardware store for a few bucks. Then go to the parts store and tell them you need x- amount of line (buy a little more than you need. Tell them you need the corresponding compression fittings as well. Total outlay will be $20 or so.
Go back and make sure you're cuts are clean, install the pressure fittings, cut your new line to fit and tighten it all down- done!
It's not as pretty as new lines but it's cheap, it's easy and it works.
Here's a few pics of a brake line that failed on a friends Chevy S-10. It was on the top of the frame and was sitting in wet dirt and leaves and grew some pin holes. We cut the line and did like I stated above and it works perfectly.
Those are brass fittings made for low pressure applications. This is a good way to die. never do this.
  #28
Old 10-09-2019, 05:48 PM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
I went and see the photo and sure enough, if I have not mistaken, a compression union with tiny brass rings that are designed to compress soft copper tubing for you fridge's ice maker. An iced stiff it would make you likely. Under severe braking the brake hydraulic pressure can be 60 bar, or near 900 PSI.
  #29
Old 10-10-2019, 06:18 AM
Andy_S's Avatar
Andy_S
Andy_S is offline
User name checks out.
  #30
Old 05-12-2020, 02:59 PM
Eurothrasher's Avatar
Eurothrasher
Eurothrasher is offline
What driving 244K miles on New England roads will do to lines made of prob inferior metals....
The rest of the car looks like it just came out of the showroom and was washed almost every other day during winter months...hand washed and sprayed underneith....
  #31
Old 05-18-2020, 08:56 AM
ECSTuning is online now
Received 2,100 Likes on 1,873 Posts
Thats what mined looked like, ohio salt brine killed them.
  #32
Old 05-19-2020, 06:59 PM
ssoliman's Avatar
ssoliman
ssoliman is offline
Someone here did a COMPLETE write up on this just recently. Something “$500 dollar bargain mini...”
  #33
Old 09-20-2020, 09:26 AM
noodlesandsam's Avatar
noodlesandsam
noodlesandsam is online now
For those of us in that movie - https://www.northamericanmotoring.co...es-really.html - not fun.
DaHose
06-29-2019 10:42 AM
Greenmachine13
Tires, Wheels, & Brakes
06-07-2017 06:29 PM
micromini234
06-06-2013 02:39 PM
Barrettrw11
03-15-2010 04:46 AM
WLSH BST
Suspension
15
01-15-2008 07:05 PM
Quick Reply: Hard brakeline replacement
