R53 2005 water pump
Vendor
Haven't seen any of them on the R53 come with a metal impeller. But that hasn't been the issue on them as they usually just end up leaking.
But only go with the Original MINI pump as we have had many issues with aftermarket, even gates, pumps leaking. The Factory MINI one has a 2yr warranty, but we've had much better luck with them.
https://www.waymotorworks.com/r53-water-pump.html
Yes I think there is a metal impeller type out there. Also think you only get the SC side as the portion facing the throttle body must be used from the existing.
The car must be placed in "service mode" and then you either have to take the supercharger off or remove the upper bolts from the throttle body to get the pump off. While in there it is logical to also change the t-stat and t-stat housing. If you are not somebody that enjoys working on motor that is made for the hands of an elf that works for Santa, then I would suggest you listen to Way and put the best pump on you can.
