Clutch Noise
Clutch Noise
Hi All,
Just bought my 04 Mini S last week. 58K miles on it. When I was looking I was trying to find one that had the clutch already done but couldn't find one even with ones upwards of 80-90K miles.
Anyway, this morning pulled into work and at idle there was a knocking noise coming from passenger side. Was scared it was an engine knock but after more investigating it goes away when clutch is depressed. So I'm thinking throw out bearing perhaps?
I'm more just wondering if I can just keep driving and deal with it when I do a clutch. There is no slippage at all. Can I keep driving until the clutch wears out more or do I run the risk of other damage?
Thanks!
Thanks!
Passenger side is opposite from the transmission/throw out bearing. On the passenger side, check your belt tensioner (the little shock can be shot and the tensioner will bounce around), the passenger side motor mount (look for black goo coming out the bottom, the crank pulley (loosen the belt and see if you can push the pulley in so that it hits the engine, if you can the pulley is bad) and last the timing chain.
Mine is bad and I think it transmits the noise to the fuel evap thing on the passenger side of the engine.
