Misfire at a loss (help)
Hey all,
My names Ryan and I'm new to Mini and have had a R53 (06) for about 7 months now. So let's start off with the codes.
P0301 cylinder number 1 misfire detected
P2096 post catalyst fuel trim system too lean bank 1
P0313 misfire detected with low fuel
**note the P2096 was thrown about a week before the car started to misfire but saw no mechanical / running issues.
What I've done so far is change the coil pack, changed the spark plug wires and spark plugs. The old plugs smelled rich to me which is strange with the codes I'm getting. It is a constant misfire as soon as the car is started sounds like a Subaru and smells rich also.
Anyone have any ideas what this could be. I was leaning towards doing a compression test next along with fuel pressure I'm assuming there is a test port on the fuel rail but I'm not sure because everything is under the supercharger intercooler. But wanted to get the opinion of the forum to see if there were common issues around this problem. I appreciate your help.
Thanks,
Ryan
Thanks,
Ryan
Welcome to NAM, sorry about your problems.
Going to move this to the Stock Problems/Issues section. Should get some responses.
How many miles on the car? P0301 sometimes points to a burnt exhaust valve. Try the dollar bill test. Start the car, take a; bill, paper towel, etc and place it in front of the tail pipe. A good engine and you will have a constant force coming out of the pipe and the paper/towel will extend out from the forcewith no fluttering. If there is fluttering, then the exhaust valve is most likely burnt.
A compression test will reflect a problem but necessarily define whether it is a valve or a piston issue.
