Toe In Issue... Trailing Arm?
So I've been to two tires shops that perform alignments in the past and keep putting off getting this issue looked at. Both shops have reported that they cannot adjust my rear driver side toe in far enough. See Photo. Shows left was .09 while the right was able to reach spec of .20
From what I can see, my control arms both look straight, the trailing arm is really hard to tell if its bent or not.
My thoughts are to go to a BMW/MINI specific shop for a final opinion but other than that, would it be safer to say its the trailing arm? I get that this is the kind of issue that you have to seee to really say. Just frustrating.
Vendor
This is why we recommend rear control arms even on a stock car as they will allow you to get the camber reduced and get that toe in line to improve tire life. You could have something bent, but you're close so you may not.
Just a set of lower rears could help correct?
