Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
Hi guys, my car had a check engine on for some time now. I had it scanned today, and this is the code that came up:
2AD2 Oxygen Sensor after catalytic converter dynamic response in overrun.
The ECU compares the output of the pre- and the post-cat sensors to make decisions on fuel & air metering. So they're both important. If the error code indicates a problem with the sensor, and not with something in your fuel or air (like a fugitive leak), then you should just change them out.
Your error code seems to indicate a problem with the sensor itself, so, yes, change it, or better yet, change both. At 200,000km, you've gotten about 40,000 more kilometers more than they're rated for. Consider that a win.
