N16 into N12 car
N16 into N12 car
Just picked up a shell in need of a motor
N16's are significantly cheaper than n12's are they a straight bolt in?
for those curious, water pump failed, no warning lights they drove till smoke. The Smoke was from the valve cover melting into the head. The center two pistons melted on the intake side. No galling on cams so it never oil starved afaik, there is melted piston on the cylinder wall.
I only did an N12 transmission into N16 car and so far so good. Im also swapping N18 into N14 car and it is in progress. You just have to give it a try i guess. the plugs might be different in terms of wiring harness, just double check that. for example, my N14 plugs are more square shape while N18 are more round.
