dealer price for mini cooper key fob
Old 02-20-2020 | 09:02 PM
Katgirl's Avatar
Katgirl
It costs way too much, but there is no way around it. I bought my car used, and was lucky enough to get both key fobs with it.
  #52
Old 02-20-2020 | 11:01 PM
Chevycruizer's Avatar
Chevycruizer
Originally Posted by chaswilson
Bummer, I contacted Mini Parts Direct about a key and just received this:
I'm sorry. Our key policy has changed. The must be ordered in person and picked up in person. We are in NC, so if that will help you give me a call and I can explain the process.
Bummer...I still needed one key for the second Mini that I purchased.
  #53
Old 02-21-2020 | 09:35 AM
valvashon's Avatar
valvashon
I recommended MINI of Peabody to a MINI owner earlier this month (Feb 2020) and they responded a few days ago that they were able to order from them via the mail. $143 for the round fob, $33 for the pull out key and $13.50 shipping via UPS. This owner is in New Jersey so they don't require an in-person visit.
Hope this helps-
Val
The following 3 users liked this post by valvashon:
MINI_42 (07-19-2020), MVPeters (11-15-2022), pilotart (02-25-2023)
  #54
Old 04-13-2020 | 04:27 AM
gone_motoring's Avatar
gone_motoring
^^^^^^excellent!!
Yes, just went to the website and the key fobs are listed as "not for sale". Will go with Peabody!
  #55
Old 11-02-2022 | 12:27 PM
perlabella's Avatar
perlabella
Digested this thread and decided to reach out to MINI Peabody...
as of Nov 2022, the cost for a 2nd key fob is $360 + tax through MINI Peabody
I also checked my local MINI in Ramsey, NJ - the cost there is $395 + tax
Not surprising, just passing along the updated info
  #56
Old 11-02-2022 | 02:29 PM
sp_clark's Avatar
sp_clark
Not Anymore...
After nearly ten years & 92,000 miles I traded my '13 Clubman a couple weeks ago. Done w/exorbitant dealer shop rates, ludicrous mark-ups for OEM parts.
Need a clutch?
Take the engine out.
Need a timing chain & guides?
Why spend $6,000 in repairs on a vehicle that's worth maybe $5,000 in trade given that something else pricey to get fixed'll break soon?
Vehicles not well-suited to NA driving conditions.
  #57
Old 11-02-2022 | 02:45 PM
valvashon's Avatar
valvashon
Just checked, these are still the prices at Seattle MINI. Add $20 or so for shipping:
Second Generation keys:
51212756061
Integrated key ($35.04 at Seattle MINI)
66123456368
Radio remote control (159.12 at Seattle MINI)
315MHZ
parts.seattlemini.com
Val
  #58
Old 11-15-2022 | 09:25 AM
Thinksmall's Avatar
Thinksmall
Another data point, Nov 2022: $662 for replacement 2017 key fob/key in San Francisco
  #59
Old 11-15-2022 | 04:29 PM
Thinksmall's Avatar
Thinksmall
And another data point from Marin Mini: $395 for fob and key + $225 to program for comfort access. There's only 2 positions for comfort access keys so if you lose one, you need to pay to get the new one associated with one of the positions.
  #60
Old 12-12-2022 | 04:03 PM
NoBrand's Avatar
NoBrand
Need a clutch?
You got rooked man.
Neither of those jobs require the removal of the engine.
the closest is the clutch change, where you have to drop the transmission. But that's relatively easy compared to removing the engine.
The jobs are easier (other than all the things you need to remove in order to remove the engine) if you take the engine out, but it's not required. If they told you it had to come out, they were charging you more to make their jobs a little easier and pad thier pocketbook a bit more....
  #61
Old 10-16-2023 | 08:52 AM
Klawtrax's Avatar
Klawtrax
Originally Posted by sgscomps
If your replacing the fob and slide in key w/o comfort access the $230 sounds about right with taxes, add around $60 to that if you have comfort access and then programming on top of that only if you have comfort access and want the comfort access feature to work. If not all you do is put the new fob in the slot and start the car and it finishes programming itself to the car. Keys and fobs can only be ordered from a MINI dealer, anyone that sells them on the internet and says take them to the dealer for programming won't work.
can the comfort page be added to a mini that doesn’t have it? I would love to just keep fob in my pocket.
  #62
Old 10-18-2023 | 04:34 AM
MiniToBe's Avatar
MiniToBe
You could, but to find a separate wiring harness, sensors, and CA module may not be cheap. Not only that, you have to change the keyfob as in program a CA fob and add the option to the CAS.
motorapido
07-08-2016 02:45 PM
chastings68
08-02-2014 12:54 AM
Nicole Grove
10-23-2012 11:29 AM
Wilco
08-07-2012 07:40 PM
manu06
04-18-2007 07:40 PM
Quick Reply: dealer price for mini cooper key fob
