Ignition Help?!!
Ignition Help?!!
Hello all,
I have a 2009 Clubman and when i insert my FOB key nothing happens the car doesnt seem to register that it is inserted, I have replaced the battery to the key and it still works when locking and unlocking doors etc just not for the ignition. Does anyone have any idea what the issue could be? I cant seem to find a shop anywhere near me that can find/fix the issue which i assumed was the actual ignition piece in the dash.
Any advice would be more then helpful
Thank you.
Also I will be more then happy to answer as many questions as needed or even upload a video of the issue if it helps! From what i have been told the ignition can only be replaced by a BMW/Mini place because it has to be reprogrammed even if its just the plastic piece.
Thank you.
PelicanParts.com (08-07-2017)
Are we talking about the ignition stop/start switch? If so, it's plug and play (no programming needed).
We have them here: http://www.pelicanparts.com/catalog/..._pg2.htm#item5
DIY for an R56 here, but gives you an idea: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
