Some serious trifecta issues!
Hi,
I had a friend of a friend replace my broken wheel bearing and during the process he broke the abs sensor, thats when the abs/dsc/tp lights went on.
He told me they would go away if I put a new sensor back on so I did but it did not solve the problem.
Ive then had the same wheel bearing and abs sensor replaced again with no luck, the trifecta is still there.
The lights comes on when I go above 20 km/h.
Please help me out, this is starting to get annoying!
I dont know about the wires, could that cause any problems?
if the wires touched when he broke it, it is a problem. to explain, i bought a car with front end damage. the MAF sensor broke and the wired shorted. after getting the car fixed, the CEL came and did want to turn off. I replaced the sensor twice with no luck. I replaced the DME/ECU and the light went away.
ask you mechanic to get readings from the sensor, like speed, voltage and compare it to the other sensor. worst case scenario, you'll need an ABS module.
