CVT problem - weird HELP!
I changed my tranny fluid and filter in my 06 non supercharged mini and everything was fine except for a slow drip nat the drain plug. After a few weeks, all of a sudden, when I take off, the tranny suddenly drops into high "gear" and won't get out. I drained the tranny, found it a quart low and refilled it. Problem remained. I did an ECU reset using ignition key and odometer button, and it worked perfectly until I cam to a stop, and then the problem started again. I repeated this process a few times always with the same results. I can't do an ECU reset every time I come to a stop. HELP! 06 convertibe non supercharged. 96,000 miles.
It is obviously an electronic control problem since resetting the ECU makes it perform properly. I don't expect it to last forever, but I DO expect to correct the control problem and use it. I'm pretty sure the Redline synthetic CVT fluid and new fillter will contribute at least a little bit to its longevity.
Took it to the Autohaus. They said it has internal problems but did not say what they were. It would not re-adapt using their BMW equipment. They did say that the red tint in the fluid shows that the previous owner (or car lot) had filled it with regular transmission fluid. That brings up a question: since it worked fine on regular transmission fluid, but slams into gear and immediately shifts to highest ratio with CVT fluid, maybe if I refill it with regular ATF and see if it starts working right again. I have a lot of leftover Amsoil ATF that's probably ten years or older. What have I got lose? It's an unsellable brick right now!
