Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
My hatch doesn't like to stay open. I need to replace the hydraulics deals (which I don't even know the name of). Has anyone done this? Is it complicated? Where would you suggest buying new ones.
There should be some videos on Youtube on how to remove. You need to put a small flat tip screwdriver and pry the metal pressure clip a little. The new ones will just install by pushing the new unit over the round bearing type node that is on the car.
It's not complicated and should take about 5 minutes to replace them. It's easier with two people so one can hold the hatch up while the struts are being replaced.
