cv axle & engine mount replacement
i have 03 mini cooper s manufactured in 10/2002 with 85k miles.
as I posted below,
https://www.northamericanmotoring.co...s-leaking.html
there was a leak and mechanic told me that there is a problem with cv axle (passenger side). the leak was grease and also found out engine mounts were compressed as well. I researched all the parts from amazon It needs to be replaced.
i think it's really cheaper than other products so anyone who had experience with this part, please let me know how it works.
Do I also need to replace rear engine mount?
Please check the link below
axle from ebay
http://www.ebay.com/itm/New-CV-Axle-...tRQ3cL&vxp=mtr
axle from amazon
Engine mount
Rear engine Mount
as I posted below,
axle from ebay
axle from amazon
Engine mount
Rear engine Mount
Axles-- A1 Cardone Remanufactured. $70 a side. All day. Best bang:buck.
Mounts-- for price, go to pelicanparts.com and select the "OEM supplier" of the required part. Don't go crappy aftermarket on mounts. They'll break in a week.
My actual recommendation (if you can swing it):
- TSW upper mount (lifetime replacement/modification at expense of some NVH) $150
- BSH lower mount is nice too. Will vibrate a lot though. But your shifts will be so deliciously solid.
- Powerflex mount inserts are nice as well. Available on waymotorworks.com
