Passenger door window
I got back home yesterday from a 4 month RV trip and tried to start my MCS but the battery was absolutely dead, not even dim interior lights. So, I put my charger on for couple hours and then she started right up. Everything seems normal except my passenger door window won't go down....driver side is fine and the passenger window was working fine when I left. I can hear the window regulator "click" when I operate the switch.....does something have to be reset for the window to work after a dead battery or did the regulator likely just fail? Thanks for any info!
Hold the button down for the window
And with the other hand punch the door where the motor sit.
Works every time. I fix 5 minis doing that. Hahaha
the rubber window seal may have "glued" itself to the glass. Mine does this when it is too cold or too hot or just plain moderate temperatures. I give the glass a very light Fonzy and all is good in the up and down world of the windows. Seems to unstick the weather seal or bumps the motor so that it works. Either way, seems to work... for now.
I used to have a royal enfield bike that required a fonzy. The starter motor would get stuck just between two magnets/coils and there would not be enough power available to move it. Smacking it with a screwdriver handle was enough to vibrate it to the next closest magnet and it would work fine. Funny stuff, but it builds character, right?
