What’s that sound? Woodpecker?
hey guys,
was hoping I could get some help identifying what this sound is. Sounds like it’s coming from chain side. New tensioner and rails though. Sounds kind of like a wood pecker. Gets faster with rpm and can barely be heard under higher rpms, pitch gets higher with rpms as well.
Video of the sound:
thanks
Video of the sound:
thanks
To the previous reply, clutch motion has no affect on the sound.
So to clarify, when the "woodpecker" noise is present, does it go away (or not) when you slowly depress the clutch pedal (then slowly release) at engine idle, not in gear?
The spinning flywheel is about 1-inch away from the throw-out bearing, and if it's chattering due to being worn or shot (yes, you can hear T/O bearing chatter at idle), there's the potential to chatter even more when the engine RPMs increase, maybe causing the higher-pitched sound you're referring to.
You did state that the noise "Gets faster with rpm and can barely be heard under higher rpms, pitch gets higher with rpms as well."
Just trying to rule out the T/O bearing as the source of your noise.
I concur it sound awfully like a belt tensioner bouncing. I recommend checking everything that the belt touches, including the main crank damper pulley. The sound have the signature of give and take tension change of the belt.
For me I would use my trusty piece of 4-foot PVC hose as stethoscope to home in on the source of the sound. It works for me 99% of the time.
pvc hose
use a soft hose of about this diameter and keep it clear from anything that moves
![](https://cimg4.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/1200x900/80_img_8309_939274c6b0d9f1ad306b87d610c1927e250e252d_b6703f910dff266dadab5ef0605a1a3fda7f0378.jpg)
I bought one of those Harbor freight stethoscope and it simply does not work. I felt stupid of wasting a few quid
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
