Stage 2 JCW power?
Stage 2 JCW power?
Just wondering, what kind of power are you JCW sized turbo guys putting down with a Stage 2? Can be an S with upgraded turbo to JCW sized. I've been teetering between the 40mm and 42mm JMTC turbos for a bit now and I'm now leaning towards the JCW. This is my daily so I'm trying to keep some reliability. Idea of JCW + meth intrigues me more than going 42mm. Thanks in advance.
Here's a dyno video of someone on here with a jcw turbo and meth. https://www.northamericanmotoring.co...ded-badly.html
S = higher CR vs JCW
If you are tuning an S.. you have slightly higher compression ratio vs a stock JCW. That said.. I would hesitate to go with a 42mm compressor.. unless you plan on a full pro-tune [possible new injectors]. You will be knock limited on the JCW turbo already; meth will definitely remedy this for you and allow for increased timing. Of course..adding meth will require a tune as well to pull more power from the lower IAT.
another consideration.. you don't have forged internals..making more power from increasing timing is likely safer than pushing more boost pressure. *though I'm not a tuner..im just the driver.
I have debated some of the same upgrades. But honestly, my car is pretty quick. And best of all, it works every day consistently and is super reliable! I don't want to open the motor and then Start having bigger issues. More power is really addictive. Especially when spanking a Mustang or Camaro! LOL
