dtc n/a,gas cap check, small,gross vapor leak
![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
In the process of replacing the short block, I had changed the solenoid/purge vapor valve which sits mounted on a bracket in the right front of the engine held in place by one of the support bolts (because it was old). On a just maybe premis I reinstalled the old purge valve and cleared all trouble codes and all idiot lights
![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
The interesting feature about the purge valve is that beneath the upper hose input pipe is an adjusting screw to enlarge or decrease the vapor entry port which I found by accident when the covering plastic fell off the new valve when I removed it. Keep that in mind when changing purge valves: the valve adjusts.
As matters stand now, all is good.
Glad you got it all figured out and glad we could help you replace some items that needed fixing.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
888.280.7799 | 6am - 5pm PST
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic118226_4.gif)
