2006 Cooper S lights on dash come on but will not even click to start
I started having problems starting when it was run for a while. Then the wipers would come on every time I started. Now it will not start cold. I have taken the ignition switch apart and nothing out of the ordinary was present (on arcing or corrosion). Is there a fuse or relay I should be looking at? Help Please
Going to move you to the Gen1 Stock Problems/Issues area.
Couple of questions, auto or manual? Will the car turn over if jumped? Have you tested the battery?
On the wipers, how big are you? I have good sized hands and if not careful will hit the wiper arm when I go to put the key into the switch.
Emnotek
08-17-2011 09:32 AM
