2009 MC Base Catless Exhaust Manifold?
Please don't do this. Your car will emit 10x the pollution, you'll have a check engine light permanently on, and you'll never pass an emissions test. All for what?
Are you sure your cat is failing? Any codes set?
I discovered on my wife's Subaru that a P0420 (catalytic converter below efficiency) can be caused by a leaking exhaust manifold gasket. All I had to do was tighten the nuts holding the exhaust manifold to the cylinder head.
Check what codes are set and then fix the problem. Could be a leak in the exhaust system or a bad oxygen sensor, both simple DIY fixes.
Magnaflow has a lower priced xat system here as an option: 48 state legal.
https://www.ecstuning.com/b-magnaflow-parts/direct-fit-exhuast-manifold-with-catalytic-converter/49028~mag/
