air in master cylinder - HELP!
I replaced my slave today and while doing it lost the rubber seal inside. while I was looking for it all of the fluid came out of the line - it stopped dripping. I found the seal, put the slave back together (i FULLY compressed it with a tool etc). I then bled it fully until no bubbles came out. But when I hit the clutch, it has no resistance and I can hear air in the cylinder at the clutch itself.
I'm assuming I have air in my master cylinder. I bled the brakes just before the slave and they have a VERy solid petal.
How can I get fluid back into the master? I have a motive bleeder setup. Does keeping the pedal in overnight bleed it?
My car is up on stands immobile at a friends, any quick reply sure is appreciated!!
Just a follow up... did three motive bleeds in a row and finally saw a good amount of air hiccup out. I did the method of pushing fluid into the lines from the slave till I had a tiny bit of pedal resistance all the way in, then next time I bled, I saw the air pocket come out.
I havent driven the car yet, but the pedal feels like before. Doing the stick trick now for good measure, hopefully its good to go in the am.
