P1611 code after jump start
so i just recently bought a 2006 Cooper s convertible mostly for the wife. It needed a few things to make it right for the road however the other day the battery drained an I used a jumper to start it however I soon realized the SES light was on and so was TpMS light and yellow hazard light with arrow around it pulled the code n it says p1611 I have looked for some info online however not much about it
can anyone help me out
Going to move you to the Stock Problems/Issues area.
1611 is a transmission module issue if I remember correctly but can be something as simple as the battery cable not having a good connection. How many miles on the car? How old is the battery? Have you had the battery tested?
could it be the the transmission control module??
I checked the volts while running with multimeter n it's running at 13.99 volts
i even tried disconnecting the batter for 2hrs to see if would clear and as soon as I started it was on there I thought usually codes took awhile to appear
I think I would do-the-cheap-stuff-first!
Disconnect the battery altogether.
Sandpaper the cables, terminals & ground connection points - don't reconnect them yet.
Find the ground strap by the right side engine mount, take it off & sandpaper it - re-install it tight. This seems to be the critical one.
There are 8 more ground points! There's a list here somewhere but I can't find it.
Re-connect the battery cables tight.
Fingers crossed & start the car.
