Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Hello everyone! So I was watching ModMinis video about removing the crank pulley and I'm having trouble.... he said to put it in 6th and have someone press on the brakes, but when I had someone do this and when I took a breaker bar to the crank pulley bolt, the bolt and pulley spun together and I can't loosen it. Any advice?
If you have both wheels off the car or the driver on the ground you can put a screwdriver in the rotor to keep it from turning. Once it pops it will come off easier.
that worked great thank you!! I will most likely be starting another thread about the timing chain and all that once i get there!
