trans fluid change on a manual
Manual Trans fluid here DIY here. I would do it at 100K. Most of the time 100K is the time to do all the fluids and since you just got it, its piece of mind to have them all done.
https://www.northamericanmotoring.co...-07-non-s.html
Vendor
Welcome
We usually recommend changing the trans oil at a 100k anyway so it's a good idea and you will likely notice it a little easier to shift with some new MTL rather than the stock fluid
https://www.waymotorworks.com/redline-mtl.html
also like said before a good time to check the belt for any cracking. And also some spark plugs if they haven't been done.
