Need the Doctor.....
I get a small smell of burning in oil when the R53 is warm. No smell at all when cold. Engine temp stays stable, just under the "half" tick.
No spots in the garage, nothing underneath, oil level is stable, tailpipes are clean...
Valve cover gasket replaced July 2017 and assuming the MINI shop did it right.
Thinking oil filter housing gasket, but unsure.
Looking for diagnostic techniques & suggestions that I can perform to find the cause of that faint smell....
Thank you, community, for the helpful posts.
Are you able to jack the car up, clean the engine off and then see where the oil is leaking? For me, if you are smelling it than would think its getting on the exhaust manifold. For that thinking the valve cover gasket. You can see the oil filter housing in Post #6 of the below thread. IMO the oil would have to be blowing out the housing in order to get over to the exhaust pipes.
https://www.northamericanmotoring.co...ant-pipes.html
Thanks for the update. Good you found it.
