Wont start: P0335 Crankshaft Position sensor error
#26
Get this.
Somewhere between trying a new coil pack and replacing it with the old coil (as well as replacing the cam and crank sensors) I got cyl 3 and 4 wires reversed (working at night, ugh!). Obviously not helping the issue. Put in correct order. Tried starting again, no go. (but could have been flooded)
Then I read the throttle body may be the issue, but will run if the wiring is disconnected.
So I disconnected top clip. No go. Disconnected lower three wire clip (hard to reach but could get 1 finger in there to lift "up and out" gently on the tab. Boom! Fired up and stayed lit, albeit, wonky, but running!. Plugged that wire clip back in and it runs as good as when this whole mess started.
So, perhaps the Crank/Cam sensors did the trick initially but could not get turn over to occur because of the wiring? Or perhaps the throttle body was stuck and needed to be reset, or perhaps there was a ground at the throttle body wiring or dirty connection.
Idiot joy! Will monitor over the next few days.
Now need to sus out the "no LED" Tach gage. Probably time to replace.
Thanks for all of your suggestions. :-)
#27
Get this.
Great to hear that you are back in business. Odd what was shutting you down. Your Mini should run well now that everything has been swapped out and replaced.
At the very least, one hopes this will help someone out down the road who falls into the same fact pattern.
Glad to hear it. Let us know the SITREP once you have some more miles under your belt.
Cheers
G3NSM0R3S
11
05-12-2015 07:34 AM
