fuel shutoff after injector replacement
Hi everyone. i have an issue with fuel shutting off after injector cleaning and a seafoam treatment. was doing just fine then fuel cut off for some odd reason. feed pump in tank runs when direct wired but nothing when key is on and starter is pushed.is there a reset switch somewhere or a workaround to tell the darn thing to gimme some gas? any help would be appreciated. been working on this thing for a month..bought it for wifes xmas present..2011 clubman s. replaced coils/injectors/cam sensors/knock sensor/crank sensor/all vacuum lines/plugs. seafoamed through intake..massive carbon showing when i hit it with endoscope. misfire on 3 this whole time but after first treatment it started firing with huge knock in 3. then poof..fuel shutoff.compression test on all 4 cylinders topping at 210psi. removed valve cover. chain tensor perfect..chain nice and tight. very clean. new turbo. im running out of options and have gone through threads everywhere for fixes. recleaned injectors after fuel shutoff and soaked plugs..only tips.. and removed carbon. saw on a thread that maybe a reset under/near/on airbag unit so stripped interior and found NADA! fuses good. before all this i hit fuel pump with pressure gauge and had 72.5 so it was within spec. going to detail interior hard since the seats are sitting on floor in garage right now after stripping carpet to see if the reset was where thread says..lol. im running out of thoughts on this. THANK GOD im an older guy with a ton of patience. any help would be AWESOME and ty in advance for any thoughts/suggestions or even any your an idiot Dave comments. MERRY CHRISTMAS EVERYONE!!!
stormreaper (12-26-2017)
no codes. had cleared them..have a scanner. prior to this it ran on 3 cylinders..no fire to #3. plugs into ecu checked. all ignition wiring traced and checked. all injector wiring traced and checked. when seafoamed #3 tried firing with a big knock then fuel cut off.after initial treatment the car started running much better then after a short drive #3 started firing but as i said a huge knock started..preignition..and fuel said adios.im starting to lean to the hpfp issues known with vehicle and taking it to mini in morning for a warranty check on it. they are gonna bend me over guaranteed but i need to get this going. starting fluid through map port on intake fired the cylinders just fine with some knock in 3..never caught on from fuel starvation..sigh.only codes from before were p303..just that.i also replaced fuel relay.
so, to back track a little, we know in order for the engine to operate, we need 4 things: 1- air/compression 2- spark 3- fuel and 4- timing.
you checked 1 and 2. 3 is also checked and under investigation for now. can you check 4. is the timing set correctly?
how did you know that 3 was knocking? did you check the knock sensor? did you check the crankshaft sensor?
stormreaper (12-28-2017)
MidwayMountaineer
06-27-2022 07:39 AM
theunclesam
01-03-2014 08:29 PM
riff42
12-19-2011 05:33 AM
hiherson
03-06-2011 05:48 PM
Chitown_COOP
01-18-2004 06:58 PM
