New key but car wont start
Old 01-16-2018, 12:09 AM
rkw's Avatar
rkw
rkw is offline
I don't know of anything under the seats related to starting the car. Just things related to the stereo, and under the center console a yaw sensor for stability control.
Make sure that you've eliminated the trivial stuff preventing start, like clutch pedal switch if it's manual transmission or brake pedal for automatic.
Originally Posted by kromerok
Its a convertible, the windows were down and the rains from about a week ago in LA killed it
The footwell module controls the windows (and a lot of other things) and it can malfunction if it is wet. The footwell module is behind the side panel in the drivers footwell. There is no access panel and you'll have to pull the trim panel to check.
  #27
Old 01-16-2018, 04:53 AM
kromerok's Avatar
kromerok
kromerok is offline
I didnt think about the brake pedal. I wouldnt even know how to go about checking that any ideas?
  #28
Old 01-16-2018, 03:12 PM
kromerok's Avatar
kromerok
kromerok is offline
Does anyone know which fuse controls the power to the dashboard?
  #29
Old 01-16-2018, 05:30 PM
kromerok's Avatar
kromerok
kromerok is offline
I was about to work on the suspension and upon removing the wheel i saw a pink fuse the ones that are see-thru on the top but i have no idea where it goes. Its a 30A are there only fuses in the junction box and engine fuse box? I attached an image of the fuse.
This is the fuse
  #30
Old 01-17-2018, 02:54 PM
kromerok's Avatar
kromerok
kromerok is offline
I was wondering if anyone knew what the relay in the upper left corner controlled and also if the engine fuse box was missing any fuses?
Still can't figure out if that pink one is coming from this car or got dropped in there by someone previously
  #31
Old 01-17-2018, 03:13 PM
Rich Rodichok's Avatar
Rich Rodichok
Rich Rodichok is offline
Disclaimmer. Just trying to help. Not giving you advice. That said, this is a pic for comparison. 2012 Countryman S, manual. I have a 50A fuse in the slot where you have a 40A. And my top slot is open where you have a 50A. Don't know what any of these fuse locations is for. Sorry, best I can do. Hope it helps. I feel you frustration.
  #32
Old 01-17-2018, 03:31 PM
kromerok's Avatar
kromerok
kromerok is offline
I looked on the diagram on back of the fuse box cover and yes a 50 goes in place of the 40. Trying to figure out where I can find some relays to swap out now
  #33
Old 01-17-2018, 03:54 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Depending on the options, under the driver seat you have the bluetooth module and amplifier. Under the passenger seat you have the YAW sensor, comfort access module, and retracting morrirs module.
Check realoem.com for electrical relays and location of things in lue of the websites provided above.
Also as I mentioned before, you absolutelty need ISTAD and ISTAP with k+dcan cable.
  #34
Old 01-17-2018, 04:03 PM
kromerok's Avatar
kromerok
kromerok is offline
Can I ask where you purchased your cables?
  #35
Old 01-17-2018, 04:08 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Ebay :-)
  #36
Old 01-18-2018, 05:30 PM
kromerok's Avatar
kromerok
kromerok is offline
After cleaning the passenger fuse box this symbol has now started to show up intermittently.
It still doesnt start but this is progress
Michael Ravellette
03-05-2023 03:44 PM
olson187
04-17-2017 05:49 AM
kpmcl
02-23-2016 09:16 AM
Mini R56
02-06-2014 09:15 PM
Thomas1
11-10-2011 09:59 PM
Quick Reply: New key but car wont start
