Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
I hope this is all it is. It was definitely oily down there even when I just unplugged the connector. I had no idea it was so readily reachable. I guess I'll need to figure out how to mount some gauges this summer... I am not too keen on extra gauges floating around but... hey... way better than an idiot light!
Thanks, everyone. Truly appreciate your input/suggestions/help.
You don't necessarily have to mount the gauges in the drivers compartment. On my TR6 I have a hour meter and fuel pressure gauge under the hood. I have a rebuilt engine sitting on my run stand with a oil pressure gauge teed into the oil pressure port for pre oiling and startup.You have a light to let you know when you have a issue, the gauge will let you know if the light is correct.
Another option is to use a Veepeak or one of the other Bluetooth devices on your ODB2 port to transmit all the engine data to your phone. I am not familiar enough with the MINI to know if it will give you actual Oil Pressure but would assume it will tell you the status of the light. I use the Torque app for my wife's MINI and my F150. I am sure those more familiar with the ECU on the MINI can provide guidance.
Happy Motoring Safari
Does this sound like knock? Was a sound from what seemed like the timing case and another from about cylinder 3... Can't catch a break with this car. This wasn't fully warmed up, but it sounded bad enough that I didn't want to keep running it. What's your take?
I think the timing chain tensioner may have given out due to the low oil pressure, but there's definitely bad things in mine. I actually just ordered a long block from All Mag Auto (can't tag users here? Seems silly).
