Anyone knows where these gaskets/o-rings go?
The white ones are fairly hard plastic and are the updated intake cam "rectangring" made of teflon, part# 11317587757 . These replace the metal ones. The metal gasket is for the N12 motor. Still not sure about the other two smaller o-rings.
If you don't find these gaskets during disassembly, you shouldn't need to worry about them --- just replace the gaskets you find. Depending on what you're tearing down, there's bound to be extra gaskets in the kit.
If I knew which engine the set was for, I wouldn't have responded. My '07 N14 intake cam only has 2 rectangrings, and none on the exhaust cam. Also, my head gasket kits don't include either your metal gasket or a throttle body gasket, it has only N14 stuff that's used for the head. But, I don't use Felpro either, at least not yet.
Which set do you use? My ideal set would have the vacuum pump o-ring, HPFP o-ring, and fuel injector bits that this set did not.
This set is for a N14 and came with an exhaust gasket instead of the head gasket. It is strange how it includes n12 stuff. The extra 2 rectarings are for the n12 exhaust cam. I'm kind of OCD about using everything is a set especially when the set costs $121 shipped. I'm always thinking, did I miss something somewhere?
Filmy
06-22-2011 12:18 PM
