R56 need help
Old 03-28-2018 | 07:01 PM
MiniCooper_S's Avatar
MiniCooper_S
Originally Posted by Pramuk
There is no oil in spark plugs hole or wall crack But thats I worried is there have some very small metal pieces dropped down in the spark plugs hole cy1 and cy3. I used paper towels to clean inside the hole bit can not clean the deep hole.
What is compression test? Oil level is fine
  #27
Old 03-28-2018 | 08:12 PM
Pramuk's Avatar
Pramuk
Originally Posted by MiniCooper_S
Thanks. Will check it out.
Or can be carbon buildup in intae valves?? Cy1 and Cy3
  #28
Old 03-29-2018 | 12:11 PM
Pramuk's Avatar
Pramuk
Hello everyone. I just got answer from mechanic. They said that cylinder 3 has low compression. It would be a couple $$$$ to open and inspect it.
Wha is the best suggestions for me to do it?
  #29
Old 03-29-2018 | 12:23 PM
MiniToBe's Avatar
MiniToBe
what were the numbers?
where is the compressed air leaking out of?
take it to another shop for a second opinion.
  #30
Old 03-29-2018 | 12:27 PM
Pramuk's Avatar
Pramuk
I didn’t ask about number. They just told me cy3 low compression and need to open to inspect. They just wait for my answer
  #31
Old 03-29-2018 | 12:43 PM
MiniToBe's Avatar
MiniToBe
in order to make an informed decision, you have to know the numbers and which cyl. you dont want to pay money specially close to 1k for inspection and then be forced to either pay to repair, another 2k or buy another engine for 3k +
ask them all the questions until you're satisfied. ask them to open the valve cover and see what is going on.
  #32
Old 03-29-2018 | 12:54 PM
Pramuk's Avatar
Pramuk
Just talked with the owner of the shop. He said cylinder 3 has 50 compression. they don’t know exactly till they open the head. And he told me that could be something dropped down into spark plugs hole and damage valve, piston or rings.
  #33
Old 03-29-2018 | 12:58 PM
MiniToBe's Avatar
MiniToBe
Let them open the valve cover first and notate the valves or anything weird.
  #34
Old 03-29-2018 | 12:59 PM
cyow5's Avatar
cyow5
They can also put a scope through the spark plug hole; no need to pull the head quite yet.
  #35
Old 03-29-2018 | 01:05 PM
Pramuk's Avatar
Pramuk
They wil charge just open the valve cover.... thats pricy
  #36
Old 03-29-2018 | 01:06 PM
Pramuk's Avatar
Pramuk
I hope they would do that.
  #37
Old 03-29-2018 | 01:27 PM
MiniCooper_S
If they won’t look throgh the spark plug hole with a borescope then you should go to a different shop.
Where red are you located?
  #38
Old 03-29-2018 | 05:26 PM
Pramuk's Avatar
Pramuk
Will go to shop tomorrow. I live in Boston MA. Here is hard to find Mini mechanic except Mini Cooper dealer:(
  #39
Old 03-29-2018 | 05:36 PM
DneprDave's Avatar
DneprDave
Here is a site that lists independent MINI shops all over the country.
https://www.minirepairshops.com/
  #40
Old 03-29-2018 | 05:53 PM
Pramuk's Avatar
Pramuk
Thanks so much. I found one 5 miles away from my home. What do you think?? Can I drive it to shop with cylinder 3 low compression (misfire) ?
  #41
Old 03-29-2018 | 07:45 PM
MiniCooper_S
That would be your call.
If it seems to run ok you could probably make it over there since the damage is already done. If it’s limping like a dog and you don’t happen to have a trailer I’d call the shop to see if they know someone close.
  #42
Old 03-29-2018 | 07:56 PM
Pramuk's Avatar
Pramuk
will see. just wait for the exactly issue tomorrow
  #43
Old 03-30-2018 | 06:35 AM
DneprDave's Avatar
DneprDave
You could sign up for AAA for about a hundred bucks and get a tow when your membership kicks in. With AAA you get four tows a year for the cost of a membership.
  #44
Old 03-30-2018 | 09:01 AM
Pramuk's Avatar
Pramuk
The shop just keeps saying I need a new engine !! Lol
  #45
Old 03-30-2018 | 09:03 AM
MiniToBe's Avatar
MiniToBe
tell them, "that's what she said" lol
take your car out from there.
  #46
Old 03-30-2018 | 09:09 AM
Pramuk's Avatar
Pramuk
Yes. Will take it away from the terrible shop
  #47
Old 03-30-2018 | 07:06 PM
Pramuk's Avatar
Pramuk
Anyone know how to clean up carbon buildup in intake valve??need to have specific spray?
  #48
Old 03-31-2018 | 07:37 AM
DneprDave's Avatar
DneprDave
Take the intake manifold off and walnut blast the valves. the only way to clean the valves is to mechanically clean them. Some have done it with chemical carbon removers, like seafoam, but they also had to use a wire brush and a dental pick to get the carbon off the valves.
  #49
Old 03-31-2018 | 08:40 AM
Pramuk's Avatar
Pramuk
Can I do it by myself? Or use brake cleaner or throttle body cleaner to clean it?
  #50
Old 03-31-2018 | 08:58 AM
DneprDave's Avatar
DneprDave
There are some very good tutorials right here.
Here is one to get you started.
https://www.northamericanmotoring.co...right-way.html
Quick Reply: R56 need help
