R53 - p0171
R53 - p0171
Hello group,
I have an R53, with 101K miles. Within the last 500 miles, I've had the fuel pump and filter changed (by a nearby BMW tech shop). Also, I have a 15% pulley that I also had the belt changed too.
The other day got a CEL and checked for codes. It's indicating a P0171. I know this MINI does not have a MAF, but (2) MAPS.
I was planning to pull the MAP to see if it's dirty. Also, I plan to check for any leaks around the SC clamps, etc. (Later today I have some time off to do these checks).
Any other thoughts or guidance?
TIA,
-Jav
TIA,
-Jav
All I can say this happened a few weeks ago on my R56 before work filled up at a gas station as it was convient , on my 85 mile commute check engine light came on with P0171 put 93 octane in with no ethanol light never came on again . Today I filled up R53 same station for convience @ 545am , check engine light came on code P0171 filled it up with 93 octane no ethanol and I will see on my home tonight if it comes on again. I Did look at temps and other items via my scanner the R53 was at 185 temp and MAP HG was 12 at idle.
Both cars run and idle great
took out the MAP, looked rather clean to me. I used a cloth and carefully wiped off the housing. didn't touch the sensor.
My son has been driving this car now. And mentioned that he has to keep up the rev's a bit, otherwise it sounds like it'll nearly stall out. (after work, I'll take her out and about for another road test).
The car sat overnight and I went out to start it up this afternoon. Turned her over, but she wouldn't catch. Tried it at least 4 or 5 times. The engine just didn't seem right turning over. Either not enough speed, or compression wasn't so good. It just "felt" odd to me. The battery is rather new too.
(This is just a seat of my pants observation). Then on the 6th time, she caught, and I really had to pump and feather the throttle until she caught. She was running really rough and "bogging down", and I had to pump/feather for about 20 seconds. Then she smoothed out. Idled just fine after that. Though when I hit the throttle to rev her up, she kind of faded slightly, and then caught up.
I shut her off, and tried again three times, of which she fire up just normal each time. (It's a nice 90F day today, so the weather is nice from a temp perspective).
Drivetrain HELP! (Please:)) SES light with P0171 code
Frodo
08-29-2006 07:16 PM
LordOfTheFlies
01-24-2006 08:20 PM
