2006 Mini S knocking noise when press gas slightly!!! Help!!!
A few weeks ago my car had a knocking noise coming from the valve cover near were the timing chain is located when I press the gas slightly, I thought was the timing chain so I replaced the timing chain, guides (which was broken), sprocket and tensioner, but the noise continued, next I put a washer as a spacer for the timing chain tensioner( last year I had to replace the engine head), and again the noise continued, last thing that I did was to replace the oil pump... and the Knocking NOISE continued!!!!! I don't know what it can be... my car has 110k miles. Besides that everything else works perfect... and when I press the gas normally I don't hear any knocking noise. Its only when you are pressing the gas slightly... any possible answer??? thanks!!!
theateist
11-10-2015 05:38 AM
rickyr53
12-16-2010 10:21 PM
perfpow
05-20-2003 10:50 PM
