06 R53 AC issue
Old 04-30-2018 | 06:05 AM
Teke14's Avatar
Teke14
06 R53 AC issue
I have searched the internet looking for the exact problem but no go. When I turn on my AC I hear a metal on metal sound like when your brake pads are getting low. the only thing I have found was the serpentine belt needed to be replaced. Is this true? I also don't have really cold air coming out of it either.
Any thoughts??
Old 04-30-2018 | 06:14 AM
Whine not Walnuts's Avatar
Whine not Walnuts
It may be a AC compressor problem. On the air temp, have you taken any pressure measurements?
Item # 20 in the below thread has some good AC information.
https://www.northamericanmotoring.co...questions.html
Old 04-30-2018 | 02:06 PM
Eric_Rowland's Avatar
Eric_Rowland
Sounds like AC bearing or other internal issue.
Have someone turn on the AC while you're in the engine bay, preferably with a long metal rod against the compressor (watch for the belt!) to see if you can determine if it's coming from the compressor body. Likely so, and you probably need a new compressor.
ArchiMark
07-05-2023 11:20 AM
TonyMastodon
10-19-2015 10:59 AM
hppsco
05-11-2006 04:48 PM
