Vibration after strut install
Has anyone had a highway vibration on acceleration appear after a shock install job? I notice a slight vibration when accelerating on the highway. My r52 is riding higher than it used to (blown shocks). Is this a cv joint wear issue? Any fixes? Ive torque checked all bolts that removed for the install.
Just me but a blown strut/shock is not going to make the car sit lower as the stance is a function of the spring. On the vibration the question I have is whether with a new strut/shock what was not noticeable with a bad unit, and yes I recently changed mine and at 50K they were shot, the new strut is transferring the vibration through?
On the pinch bolt, if you torqued it the specified value the unit should not be sliding within the hub assembly.
06SuperCoop
05-29-2013 07:04 AM
STF_U
08-20-2012 05:33 AM
BillyCuth
04-05-2012 08:39 AM
CARdiac
12-30-2009 09:30 AM
mdsbrain
10-14-2006 05:51 AM
