new to me r53 problems
First post, switching over from VW(possibly) picked up a nice 03 r53 stock as a rock, had some issues and ive cleared them all but a P1239, and ive tried everything on other forums on here, took the initiative to pull the SC off to change fluid and hopefully find the culprit in the process, the boot on the drivers side to the intercooler had some cracking, i replaced one MAP sensor and swapped them around etc, code remains off when car is running once cleared, restart and its back, can the wiring be voltage tested and is there anything else i should definitely check? If nothing else i guess ill just have to VR6 swap it.
The sensors are the same part numbers on a R53 as confirmed by RealOEM: https://www.realoem.com/bmw/enUS/sho...diagId=18_0475
The originals from the factory are NTK. You can order NTK sensors from O'reillys with free shipping. I just changed mine.
https://www.oreillyauto.com/detail/b/ntk-4463/fuel---emissions-16775/emission-smog-parts-16465/oxygen-air-fuel-ratio-sensor-12041/3cb50c2c8b72/ntk-oxygen-sensor/25648/4544055/2006/mini/cooper?q=Oxygen%2FAir-Fuel+Ratio+Sensor&pos=2
The sensors are the same part numbers on a R53 as confirmed by RealOEM: https://www.realoem.com/bmw/enUS/sho...diagId=18_0475 The originals from the factory are NTK. You can order NTK sensors from O'reillys with free shipping. I just changed mine.
joecooool
06-20-2004 10:11 PM
