Stock Supercharger pulley not aligned
Old 08-04-2018 | 05:32 PM
tedmid's Avatar
tedmid
I searched pulley and align but didn't get the right hits.
Belt on my r52 fell off, trying to figure out why. To me it seems my supercharger pulley is off by a whole groove/rib (too close to SC) compared to all other pulleys??
thanks!
Old 08-04-2018 | 06:57 PM
Tgriffithjr's Avatar
Tgriffithjr
Is the belt old and in need of replacement? If you replaced it Have you done anything besides replace the belt? Remove or replace any pulleys? It does look like it might sit in towards the engine a little but hard to tell by the photo. Did the belt seem to lay naturally in line with all pulleys before the tension was applied? Double check the belt length and groove quantity. Compare it next to the old belt. If the belt is correct and you did nothing to the engine then I don’t know. Good luck!
Old 08-04-2018 | 07:26 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I just looked at mine and the stock pulley should be just a little under an 1/8" off the aluminum supercharger frame. If that is a stock pulley I am trying to figure out how it got pushed in as it takes an act of congress to get the thing off.
Old 08-05-2018 | 08:31 AM
tedmid's Avatar
tedmid
Thanks both
So the original belt got shredded which is why I am looking for reasons why now and unable to tell how it sat before. I may temporary install a new belt without running engine to see it it is possible off. I am not the original owner either so no telling what they have done. As now it's the best time I ordered a 15% aftermarket pulley and night see how it aligns when installed..
Old 08-10-2018 | 12:22 PM
tedmid's Avatar
tedmid
SC pullley clip
Well crap...
i pulled my SC pulley off and this came with it. It's a bit deformed so not sure if I can get it back in right... Also don't think this has a part#??
Old 08-10-2018 | 09:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It was on too far so changing to an aftermarket pulley isn't going to fix it. Need to have the nose rebuilt and the shaft realigned properly.
Eddyboi77
R57 :: Cabrio Talk (2009+)
05-21-2018 09:15 AM
KMPSSBL
07-22-2012 09:47 AM
Gizmo
17
06-01-2012 02:23 PM
meb
Suspension
06-01-2006 04:10 PM
planeguy
Tires, Wheels, & Brakes
18
02-28-2006 02:31 PM
